A received index of the displayed type did not match with the index currently in the PBB Tunnel Database. This is unexpected and can indicate that the standby MM is out of sync with the active MM.
Reboot of the standby MM might fix the issue. If the problem persists, contact Extreme Customer support with details of the error message
Warning
%type% mismatch - Received Index %rcvidx% Current Index %curridx%
| Name | Type |
| type | String |
| rcvidx | uInt16 |
| curridx | uInt |
